Favor gone bad
Old Mar 24, 2010 | 03:08 AM
DJackson123086's Avatar
DJackson123086 is on a distinguished road
Exclamation Favor gone bad
Thank you
Old Mar 24, 2010 | 06:43 AM
When you say that it will not start, what does it do? Turn over and not fire? Not turn over at all?
Old Mar 24, 2010 | 08:18 AM
RaginInferno's Avatar
RaginInferno is on a distinguished road
Why were you "adjusting" non-adjustable valves on your '97 engine?
Old Mar 24, 2010 | 10:30 AM
AJBert's Avatar
Also, timing is set by the ECU. How exactly did you set the timing before and plan to reset the timing now?
Old Mar 24, 2010 | 10:31 AM
You can adjust it one tooth at a time!
Old Mar 24, 2010 | 05:24 PM
Exclamation
There are two types of rocker arms this model has the type that does need to be adjusted, I adjusted them as per the instructions in the Chilton's manual. It seems to fire, but then a puff of gas or smoke shoots out of the intake. Also, as far as timing it I'm going to just line everything back up to #1 TDC (the crank, distributor and the rotor in the distributor- though it should line up when I line up the distributor, just to be sure). I also might mention that it is the High voltage switch (HVS) style distributor.
Old Mar 24, 2010 | 05:57 PM
Time per the instructions below or you'll just waste your time:
EDI Engine Timing
The proper term for this ignition system is EDI.
nktidwel
Nov 27, 2011 12:36 AM
ChevyBlazerChick
Jun 18, 2011 11:37 AM
WHITE LIGHTNING
The Chop Shop
May 12, 2011 05:26 PM
hofford
Lifting Tech
Jan 31, 2011 10:11 PM
dieseltwitch
Sep 7, 2009 08:57 PM
