Front Clunking noise when in 4WD
I have an 03 2 door Blazer. When in 2WD everything is fine. When pressing 4WD it engages properly and drives normally. At random times, however, I hear a clunking noise from the front that sounds like a hammer hitting a solid piece of metal. There is no pattern to this as I can drive several minutes without any sounds and then it can do it a couple of times in a minute. Switching back the 2WD and all is fine. Any ideas as to what should be looked at?
Feels like it is a little more forward than that. I have the truck at my mechanic today and he does not see anything wrong with u joints, fluid levels etc, but noticed that one of the motor mounts is totally broken. He tells me the engine torques more when in 4WD and that may be causing what I am hearing, hopefully that is the case. Repair will be completed tomorrow. Thanks for the reply.
Well I got the truck back from my mechanic with the motor mounts and transmission mount replaced and I still have the same clunk/banging noise in 4WD only. He wants me to bring it back next week and bring it to a tranny place to examine the transfer case and transmission. Any ideas would be appreciated. Thanks
...besides a new mechanic? sorry couldn't resist
edit - I guess that wasn't very helpful - are you sure it isn't happening when you turn the wheel one direction or another and give it throttle? How about on uneven surfaces or rough roads? Where does if feel like it's coming from?
Look at the Drivers side Wheel Hub, I had similar symptoms aswell a second time and it turned out to be my Wheel Hub, a much cheaper replacement than what my mechanic originally suspected when we replaced my transfer case....So once again, Check your wheel Hubs, My noises started at around 90KM/h and stopped around 100km/h then the speed range progressively became wider.
TeamSumner
Jan 19, 2011 01:49 PM
rld863
Jun 15, 2009 04:29 PM
Chrismacster
Apr 2, 2009 06:57 PM
Blazin 4x4
Oct 23, 2005 06:11 AM
kwsrv@libcom.com
Sep 7, 2005 05:01 AM
