Front driveshaft????
Old Mar 26, 2014 | 02:03 PM
My97jimmy's Avatar
My97jimmy is on a distinguished road
Default Front driveshaft????
Have a 1997 jimmy and trans went out. Replaced with trans from 1997 blazer and front drive shaft will not fit! If installed the crossmember will not fit, it's as if the transfer case is about 1 inch too low where front driveshaft exits. Any ideas? Other than driveshaft issue everything else lined up and works well.
Old Mar 27, 2014 | 12:51 PM
I am betting that one of the vehicles is 4wd while the other is awd. The two transfer cases use different transmission to transfer case adapters. If the awd adapter is used on a 4wd, the transfer case will not be clocked properly and the same is true for using the 4wd adapter on an awd transfer case.
So you need the adapter from the transmission that came out of the vehicle.
gitch93
Jan 23, 2013 04:51 PM
JGarr
14
Mar 6, 2007 07:14 PM
Blasir
Feb 7, 2007 09:07 PM
Blasir
Oct 12, 2006 11:32 PM
trudynosports
Dec 13, 2005 09:40 PM
