frozen radiator need some help
Old Jan 7, 2013 | 01:51 PM
bobby099's Avatar
bobby099 is on a distinguished road
Question frozen radiator need some help
well i have my blazer in the garage for the winter, i always used 50/50 so i start it every 2 weeks to make sure everything is in working order. this week i had the hood popped open and my coolent was slushy but after 5 minutes i was getting warm heat just not hot. should i drain my radiator and use straight antifreeze?
Old Jan 7, 2013 | 01:59 PM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
No you dont want to use straight antifreeze maybe about 60/40 ratio and get an antifreeze tester to find out what the freezing point is after you fill it.I know they are less that $10 and pretty self explanitory to use.
Old Jan 7, 2013 | 03:02 PM
bobby099's Avatar
yeah i bought one of those yesturday the reason im asking is i just bought another jug of 50/50 but im wondering why its still kinda slushy like its got water in the radiator i dont have heat in the garage but its not super cold out its suppose to warm up this weekend maybe ill just change it before it gets cold again.
Old Jan 10, 2013 | 03:28 PM
grizzstang's Avatar
grizzstang is on a distinguished road
It it is freezing I would say that you have more water in your system than you think. I would drain the system and add new 60/40 ratio antifreeze as suggested above. Stop buying premixed antifreeze as you are being charged for water. Mix it yourself and test it before you put it in the rad.
Old Jan 10, 2013 | 06:08 PM
bobby099's Avatar
i already changed it out to 60/40 now im having heat issues
Old Jan 10, 2013 | 07:11 PM
rexazz2's Avatar
if you got slush you never had much antifreeze
Never used pre mixed doesnt really allow you to increase strength
I was told that straight antifreeze will turn to gel BTW
Park on as steep uphill incline as you can find
drain rad
refill slowly with engine running ,heater on
dont rush to cap the rad ,keep an eye on temperature gauge
top off rad when normal operating temp is reached and cap
Make sure you change fluid out in catch tank its also watered down
Old Jan 10, 2013 | 09:59 PM
Question
What does your engine temp get to after running a to being fully warmed up?Your thermostat made need to be changed.
sifd4x4
May 23, 2010 01:10 AM
mccague36
Dec 6, 2008 09:38 PM
mccague36
Mar 1, 2008 08:05 PM
SmokeU
Dec 29, 2007 09:44 AM
bat119
Dec 1, 2006 04:39 PM
