Fuel gauge bouncing around
Old Mar 7, 2024 | 11:27 PM
CFH4EVER's Avatar
CFH4EVER is on a distinguished road
Default Fuel gauge bouncing around
Is it something that can be fixed easily or replace the pump assembly? Is the punp accessable by cutting a hole from the inside?
Old Mar 8, 2024 | 07:31 AM
GeorgeLG's Avatar
It can be the sender unit in the tank but it can also be a number of other things like the gauge, power, ground, wiring, the class 2 serial data bus etc. You could get clever to narrow it down by say inserting a resistor of a mid tank value in the sender circuit to see if the gauge remains stable depending on your wiring and soldering skills.
I saw a post here years ago where a member cut a removable section out of the rear passenger floor to gain access to the pump unit. Be careful, sparks and gasoline are involved. My Toyota has this and it’s priceless. Blazers unfortunately, not so much.
George
Old Mar 8, 2024 | 07:33 AM
GeorgeLG's Avatar
JohnnyBlazer82
Dec 30, 2015 06:10 AM
El_Beautor
Sep 19, 2012 12:49 PM
sharrard.
Engine & Internal
Apr 26, 2011 04:55 PM
unklemike00
Oct 4, 2010 06:44 AM
sleonh
Sep 22, 2009 07:15 PM
