Fuel pressure ??
Old Jan 12, 2016 | 05:25 PM
Squatcher's Avatar
Squatcher is on a distinguished road
Ok so after corking off line and checking pressure I only have 48 psi and it did drop to 45 psi after sitting . Is it possible for it to leak back through the pump? But sounds like it does need a new fuel pump. Any recommendations on brand of pump? Oh and funny thing is it didn't leak down on first test. I'll just check everything on pump install.
Old Jan 12, 2016 | 05:44 PM
Yes it can leak back through the pump. There is a check valve at the pump outlet. AC Delco or Delphi pump ONLY!!!
Old Jan 12, 2016 | 05:49 PM
Squatcher's Avatar
Ok thanks a lot for all your help.
Old Jan 12, 2016 | 10:55 PM
blazer47's Avatar
blazer47 is on a distinguished road
Originally Posted by Captain Hook
Obviously you didn't read the link that was posted above.
obviously yes maybe I did. I've seen multiple suggestions on this forum that go in 2 different directions so when you get the same answer 9 out of 10 posters it kind of swings you to the good side of the force?
Old Jan 13, 2016 | 03:02 PM
That is precisely why I took the time to write the article. The specs and procedures are taken directly from the GM "dealer issue" shop manual.
Old Jan 13, 2016 | 08:01 PM
Squatcher's Avatar
Ok after a new Delphi pump and a little work I think all is well, thanks to you guys guiding me down the right path. Thanks to all who helped hope I can return the favor one day.
brianroark
Jun 25, 2010 03:14 PM
Spartan66
Jul 11, 2008 02:34 PM
riverjamie
Sep 24, 2007 08:21 PM
aspenpup
Sep 9, 2007 07:11 PM
jlinder
Aug 21, 2005 11:08 AM
