fuel pressure bad typically on start up?
Old May 27, 2012 | 01:06 AM
xJakeLIKEShisBLAZERx's Avatar
xJakeLIKEShisBLAZERx is an unknown quantity at this point
Default fuel pressure bad typically on start up?
first off I need to replace the fuel filter...
but mainly when I just start up and go to take off accelerating normally, and gradually even to like 25 miles an hour
it's just nope, revs up to almost 3500-4000rpms and it should be accelerating accordingly but I wont go faster than 12-15mph...
maybe fuel pump? i dunno
never experienced it before...
and on a side note, when going to pass or actually having to accelerate i don't know if its a typical blazer thing for there to be so much lag in acceleration, rpms go but mphs dont.
I wish I could drive a perfect blazer to feel the difference
sorry for the book
Old May 27, 2012 | 07:45 AM
50lb_cat's Avatar
Are you saying that you are at 3500 rpm to go 25mph? If so, then your problem is your transmission. Also what year?
Old Jun 15, 2012 | 06:14 PM
i might have been exaggerating about how high it's reving...the engine just sounds like it's blowing really hard when accelerating, but at this point I honestly wanna say its the fuel pump going bad..
cuz now it just kinda sputters, but only after it's sat for a bit, I can't tell if it's bad when accelerating on the highway, but like after 50mph it just kinda dogs it.
its a 2000
Old Jun 16, 2012 | 11:15 PM
50lb_cat's Avatar
https://blazerforum.com/forum/tech-articles-diy-29/96-fuel-system-diagnosis-23038/
That should help ya out. Do a fuel pressure and leakdown test
Old Jun 17, 2012 | 08:23 AM
JDrummond Service Inc.'s Avatar
JDrummond Service Inc. is on a distinguished road
Originally Posted by 50lb_cat
https://blazerforum.com/forum/showthread.php?t=23038
I had a similar problem with crazy hesitation under acceleration and I assumed it was fuel related. I played parts roulette and replaced the pump, filter, MAF, EGR, TPS, cap/rotor, plugs, wires... and finally it turned out to be the coil pack. GOOD LUCK!
Old Jun 25, 2012 | 10:44 PM
ohiomachinist's Avatar
ohiomachinist is on a distinguished road
I had the same problem with my 95. It ended up being a weak ignition coil. For some reason the MSD coil was cheaper than the stock one so I went with it instead.
Old Jun 26, 2012 | 12:01 PM
Zaneland's Avatar
Zaneland is on a distinguished road
I had the same issue on my 98. I changed the MAF sensor and it went away immediately. Good Luck.
buzzsaw560
Jan 30, 2012 05:04 PM
cage47
Apr 9, 2009 10:07 AM
Spartan66
Jul 11, 2008 02:34 PM
99bravada
Apr 4, 2008 05:41 PM
actionpaintball
Jul 14, 2006 07:53 PM
