fuel pump?
That is where I got my pump from, even with 2 day shipping I still saved about 100$
Alright will do and also could it just be the sender module it has good fuel pressure I did a fuel pressure test on it before replacing my spider and the fuel pressure holds steady at 58. Also I might get one from ebay there is a company in Florida that makes exact fit for $60.
Is that the pump or sending unit? I wouldn't trust a $60 ebay pump, unless you just really like dropping the tank. Delco or Delphi for sure. The sending unit, you can afford to gamble with a cheapo one. That's what I did. delco pump, cheap sending unit. I couldn't afford delco/Delphi for both, and I figured the pump was the more critical of the two. If something on the sending unit fails, I'm just out a gas gauge for awhile.
As far as the gas gauge, I would believe that to be sending unit related. Once you get it out, I think you can check it with a volt meter while manipulating the float and see if it's working properly.
As far as parking downhill/uphill, that's a new one on me. The pump is in the rear of the gas tank, but it has some baffling built into the tank to help keep the pump submerged all the time. Will it start facing downhill with a full tank, or does it only happen when you're close to empty?
I like working on mine too, what I don't like is buying the same part more than once because my eBay special took a dump on me six months later. I also don't like missing work or being stranded because of it.
Some things you can go cheap on. I like cheap, too. But sometimes you get what you pay for, and fuel pumps for these trucks seem to be one of those items.
BouncingRadical
14
Nov 27, 2015 12:30 AM
cide
Nov 7, 2009 01:26 PM
upblazer95
Mar 8, 2009 07:15 PM
mytruck2
Dec 13, 2006 04:50 PM
