Fuel Pump?
Old Apr 10, 2014 | 05:18 PM
bcase1997's Avatar
bcase1997 is on a distinguished road
Default Fuel Pump?
I started my 2001 Chevy Blazer 2dr LS 6cyliner 2.4 liter truck and it started fine. When i got home I shut it off and when I went to start it a little while later it just kept turning over. the fuel pump isn't humming or anything, none of the fuses are blown. What do you think it could be, is the pump shot?
Old Apr 11, 2014 | 11:38 AM
abig84's Avatar
2 easy ways to check at home is spray starting fluid into your intake and crank the engine and see if it fires, though not really a full proof meathod as it could be a bad fuse or relay too.
or another thing is have someone crank the truck and you can lay underneath and beat on the tank with a big rubber hammer. do that a lot at work when cars wont start, youd be surprised how many times that jar's the pump enough to get it started.
also check to make sure you have gas, im working on a infiniti suv right now that reads 1/8th of a tank, just pulled the pump out and its completely empty
BouncingRadical
14
Nov 27, 2015 12:30 AM
cide
Nov 7, 2009 01:26 PM
upblazer95
Mar 8, 2009 07:15 PM
Lckyctch
Dec 30, 2007 05:38 PM
mytruck2
Dec 13, 2006 04:50 PM
