Fuel pump question need answer a.s.a.p
Old Oct 13, 2011 | 03:57 PM
limited edition 1's Avatar
limited edition 1 is on a distinguished road
Default Fuel pump question need answer a.s.a.p
Ok guy 1 question..... I have a 2001 limited edition 4 door blazer and I need to know if I can use a pump off a 2003 4 door blazer?
Old Oct 13, 2011 | 04:07 PM
DaddysBlazer's Avatar
DaddysBlazer is an unknown quantity at this point
As long as they both have plastic tanks. I dont think theirs a differance between them, and once you have them both in your hands youll know for sure then!
Old Oct 13, 2011 | 05:01 PM
Default One more thing still need help....
My truck is a 2001 limited edition Trail blazer with a 4.3,..it's not a regular blazer.......But it is made like the 99' and up regular blazers.
Old Oct 13, 2011 | 05:50 PM
LowLife's Avatar
LowLife is on a distinguished road
yea u can use the fuel pump if u want to, as long as they are both either 18 gallon metal tanks or 18 gallon plastic tanks.....i would just take apart the sending unit and replace the pump youll need a flathead a pair of slip joint pliers and 5 minutes the pump is reall easy to change in those plastic sending units...
Old Oct 13, 2011 | 06:43 PM
Thx guys
Old Oct 13, 2011 | 06:53 PM
Your truck is just a trim level on the standard S-series Blazer so saying that it is "not a regular blazer" is not true when talking about pretty much anything other than the optional trim pieces that make it a Trailblazer trimmed Blazer.
That said, comparing the part numbers on RockAuto.com should give you definitive proof.
eclark69
Jun 21, 2012 02:41 PM
janet7
May 24, 2011 02:16 PM
shawncullen
Lifting Tech
Nov 26, 2010 05:38 PM
89K5gasahollica
Mar 19, 2010 02:47 AM
95blazer4wd
Feb 16, 2009 08:15 PM
