fuel smell after spider injector replacement *Help* please
Old May 12, 2021 | 01:18 PM
RCsurfer's Avatar
RCsurfer is on a distinguished road
Default fuel smell after spider injector replacement *Help* please
so i’ve got a 1994 chevy s10 blazer 4x4 with a 4.3l vortec motor, i was getting horrible fuel mileage and i heard the spider injectors give out in these a lot so i replaced it and it defenitely needed to be replaced, afterwards it ran smooth for a day or two then i started to get a rough idle and strong gas smell and some hiccuping from time to time while idling, after driving for about 10 minutes the cars rough idle goes away and no more hiccups but still a strong fuel smell, anybody know what the issue could be ive replaced the EGR valve and maf sensor and spark plugs thinking it would help but nothing seems to work.
Old May 23, 2021 | 11:38 PM
Mods's Avatar
you may have cracked or kinked the injector hoses when installing it, how rough were you when installing?
Last edited by Mods; May 24, 2021 at 12:09 AM. Reason: Realized this was a 1994, not sure how i missed that..
Old May 27, 2021 | 03:06 AM
Sounds like you have a fuel leak under the upper intake plenum. Perhaps a hose was damaged or a connection became loose.
What sort of FI system does it have? The CPI or Multi-port.
On a 92 I had with the CPI, the leak was in one of the lines to tbe injector(s), not at the injector itself.
RCsurfer
May 10, 2021 07:49 PM
614blazer
Jan 25, 2012 03:08 PM
00bluegtp
Jul 24, 2009 12:18 AM
mikeswhls
Oct 19, 2008 09:02 AM
92tahoe
Oct 9, 2007 03:13 PM
