Fuel System Conversion
Old Jan 21, 2009 | 02:24 PM
  #21
BlazinMike89's Avatar
BlazinMike89 is an unknown quantity at this point
Default RE: Fuel System Conversion
You think I can fit a Big Block In there? I know i can install a Small Block, If id get a 350 i would get a Manual Tranny and Change the Engine mounts and also i would have to modify the radiator fan shroud im assuming
Old Jan 21, 2009 | 02:29 PM
  #22
Anything is possible. Just depends on how much money you want to spend.
Being 2wd simplifies things as well as broadens the possibilities.
You would want to just go to an electric fan setup to save space and cut down on the headaches.
Old Jan 21, 2009 | 02:43 PM
  #23
I Would Love to throw in the 572 Chevy Crate Motor. I Know its overkill but I had a chance to drive with that engine and its amazing. I could get that and throw in a new tranny coupled to it. With that i would not need my PCM would I? Its Carbed or DoI still need a PCM?
Old Jan 21, 2009 | 06:48 PM
  #24
Different transmission without computer control and you no longer need the PCM. You would have to redo the dash though.
Old Jan 21, 2009 | 07:28 PM
  #25
Well Ill either completely redo the 4.3, rebuild and upgrades or ill just get a 350 Fuel Injected Crate Engine Turn-Key From Perfomance Unlimited. Cost About 8K for the Whole Turn Key. Drop That In an then ill just modify my 4L60E if it cant handle it, or sell that and get a manual Tranny. But i mainly would like to Rebuild the 4.3 and then get the manual tranny. My Last question is how much is a rebuild of the 4.3 usually go for? Rough Estimates will be good if your not sure thanks
Bobcat13
Nov 10, 2013 06:03 PM
94s10blazin
Aug 10, 2013 01:00 PM
liltittle62
Dec 26, 2010 03:55 PM
Cyberlight
Nov 17, 2010 07:31 AM
bigjohn1139
Jan 17, 2008 12:27 PM
