gas in oil and coming out exhaust pipe, help
Old Apr 28, 2011 | 10:20 AM
Joe Table's Avatar
Joe Table is on a distinguished road
Question gas in oil and coming out exhaust pipe, help
I have a 94 s-10 Blazer Tahoe, I'm trying to rebuild and clean up, but having issues with it sucking gas into the oil and coming out the tail pipe....i pulled a plug and it poured out of there too, i am not a mechanic by any means...im learning as i go... can someone give me some advice here......thanks
Old Apr 28, 2011 | 12:52 PM
rriddle3's Avatar
Sounds like you have a major gas leak from the fuel injector system under the upper intake plenum. Probably will need to replace it.
Old Apr 28, 2011 | 12:53 PM
Frog's Avatar
Frog is on a distinguished road
Gas poured out?? I am betting it is either the pressure regulator or the spider assembly. You have the "W" engine code correct??
Look at your VIN and count from left to right to the 8th position....should be a "W"....if so, remove the vortec cover and on top of the intake there will be a round plastic valve aka tuning valve. Pull it off and see if there is fuel inside the intake....you will need a flash light to look down inside....if so, there in lies your problem. You will need to remove the upper portion of the intake to service/replace the components inside.
Old Apr 30, 2011 | 05:08 PM
Joe Table's Avatar
Thanks Guys....I"ll check it out, I know there was an issue with the spider assembly before, I bet you two are correct... would that also cause it to smoke out of the exhaust pipe...white/blueish color?
Old Apr 30, 2011 | 10:57 PM
Frog's Avatar
White.....some but, white smoke is usually just steam if it is at first start up...in the mornings and it dissipates quickly. If it is on every start up and it hands around for a little while it could be coolant.
Blueish smoke would be oil burning....valve seals usually.
If it is running rich you could smell the fumes and it would be more of a black color....sooty.
Old May 1, 2011 | 03:56 PM
Joe Table's Avatar
Thanks Frog..... You Da Man.....ill let ya know how it turns out....
xwhyz1959
Dec 17, 2010 07:52 PM
Sherwood
Dec 31, 2008 02:36 PM
Big E
Feb 14, 2008 10:49 PM
4x4willywill
Dec 27, 2007 11:18 PM
ScottECU
Headers, Intake, & Exhaust
Jun 6, 2007 01:58 PM
