getting cylinder 6 misfire code
Old May 9, 2014 | 02:33 PM
chevy fan302's Avatar
chevy fan302 is on a distinguished road
ok just to update found that my loss in power is maf now I'm hoping its either just cleaning will fix or its just a bad connection but other than that everything is good
Old May 10, 2014 | 08:16 AM
tulsablazer97's Avatar
tulsablazer97 is on a distinguished road
how did you determine that was the problem?? im thinkn that may be my problem aswell
Old May 11, 2014 | 11:25 AM
By disconnecting it and test driving and I also was lucky that all I needed was to spray it with maf corner and it now performs with it connected
Old May 12, 2014 | 05:58 AM
I can unplug mine and nothing changes I havnt drove it while unplugged but at 1/4 throttle it does nothing I cleaned itbut no changes im thinkn that may be my problem
Old May 12, 2014 | 10:04 PM
if theres no change that could be it mine was causing my truck to run to lean so when i unplugged it it got its power back than after cleaning it i pluged it back in an now i have power. try driving with it unplugged
Old May 14, 2014 | 07:23 AM
Gr8N8's Avatar
Gr8N8 is on a distinguished road
I had a similar problem with my 96 LS 4.3...I changed plugs, wires, cap n rotor, and injector spider...
I finally replaced the distributor and it runs normal again
Try replacing the distributor I paid about $125 for a new one that came with cap n rotor.
Its worth a try...
Good luck!!!
Old May 15, 2014 | 09:05 AM
thats about the only thing i havnt changed other than the MAF
JerryB52
Jul 13, 2011 06:35 AM
mbar
Nov 10, 2010 02:39 PM
jmatt07
Dec 18, 2009 09:48 AM
1996BZR
19
Dec 23, 2008 03:07 PM
megtom2
20
Nov 6, 2007 01:07 PM
