GMC Jimmy high RPM's at idle?
Old 10-03-2013 | 11:24 PM
bdude273's Avatar
bdude273 is on a distinguished road
Default GMC Jimmy high RPM's at idle?
Hey,
My GMC Jimmy runs at around 1000RPM's when sitting, after about 5 mins it goes down to 600. Its about 12 degrees celsius out idk if that effects it. I cleaned out the throttle (it runs fairly smooth; very minimal shaking) with some carb cleaner and it runs better but still revs high. Should it be revving at 1000 or not?
Old 10-04-2013 | 01:37 AM
richphotos's Avatar
richphotos has a spectacular aura aboutrichphotos has a spectacular aura aboutrichphotos has a spectacular aura about
53°f or 12°c is chilly, so its really not out of the question to be up around 1000 at that temp. the fact that it drops after about 5 minutes to normal is indicating that its the choke that is on.
Did it just start doing this now that the temp is starting to fall? or has it always done this, even when it was hot/warm outside?
Old 10-04-2013 | 05:56 PM
bdude273's Avatar
it has always done it whether its 27 degrees or 5
bear159
12-07-2023 09:11 AM
mcdevin1973
10-05-2014 02:52 PM
vonholt53
18
02-23-2013 03:04 PM
wollefdoog
10-27-2011 11:13 PM
londonmazda
10-19-2010 02:15 AM
Quick Reply: GMC Jimmy high RPM's at idle?
