Good ideas, got any?
Old May 23, 2010 | 06:18 PM
jimdian's Avatar
jimdian is an unknown quantity at this point
Default Good ideas, got any?
No, I don't have any, but any good ideas while its apart would be much appreciated.
We are dropping an 01 engine into a 99.
I figure I should flush the coolant same day I get it back (I run the green)
Main seals?
I can't really think of anything else that would be done best while apart, many thanks.
Old May 23, 2010 | 08:13 PM
Nvidia78's Avatar
Nvidia78 is on a distinguished road
how many miles it got, might check the timing chain and replace the front and rear main seals, might as well get some ac delco double platinums in there before ya get the motor in too, will be easier that way
Old May 23, 2010 | 11:09 PM
jimdian's Avatar
It has 125,000 ks, I suppose I should change the plugs too, your right,Might as well, Thanks.
Old May 24, 2010 | 01:32 AM
LowLife's Avatar
LowLife is on a distinguished road
You are gonna have a knock sensor issue, The 99 has the 1 wire knock sensor and the threads are different also i believe, Not exactly sure if that is the right difference, But i know it is something like that.
Old May 24, 2010 | 11:40 AM
jimdian's Avatar
Well I was trying to see in the 99 what exactly is going on with that but I can't see back there. From reading here I've got a 50/50 chance I'll be alright From the letters in the VIN they both have W's in the 6th position I think it is. Will Bosch spark plugs Do Nvidia,?
Nevermind on the Spark plug question I answered it myself from the posts on here, I'll track down the Delcos when stores are open again, Thanks forum, this place is great.
Last edited by swartlkk; May 24, 2010 at 10:23 PM. Reason: **Combining Consective Posts** - Please use the EDIT feature to add information to your post if another member has yet to reply.
Old May 24, 2010 | 05:54 PM
Nvidia78's Avatar
Yeah you may pay a lil more for the Delco plugs but they are worth it, these 4.3's don't seem to run right on anything else... glad to see you are reading and learning from the forum, there is lots of valuable information here if ya take the time to read thru it.
Old May 24, 2010 | 10:38 PM
LowLife's Avatar
Lightbulb
Im not sure who told you that because you have a vin "w" you have a 1 wire knock sensor. The w is for a 6cyl 4.3l Vortec H.O. with balance shaft, Not the knock sensor you have. I just want to make sure u know that you would be better off to just get the motor with the right setup so you dont have to mess around.
Old May 25, 2010 | 07:02 PM
jimdian's Avatar
Actually I got that from talking to different shops when I was looking for a new... they were asking about there being a W in the VIN and suggested that normally you've got a year either way to get one that will fit without headache.
But then when I decided on the one to take, buddy said it was in 01 that they changed this knock sensor and You'll have a 50/50 on being alright, turns out that the piece that I belive is the knock sensor on this new engine I got, Is tapped 1/4" pipe, and from what I've read here I'm good to go, fingers crossed. wouldn't be a big deal to redo some threads if a guy had to. Fingers crossed I want my ride back theres lots o mud to play in now.
Old May 26, 2010 | 12:40 AM
LowLife's Avatar
The knock sensor is as far on the back of the engine as you can go, Right before where the bellhousing bolts thread into, If the hole was already drilled to the bigger size and the threads are tapped for you, Your good to go. Good luck with the install.
Jordan Sims
Apr 18, 2014 11:08 AM
alamantia
Headers, Intake, & Exhaust
Jan 21, 2010 05:20 PM
bjsx8f
Oct 26, 2009 11:29 AM
gizwilly
Sep 5, 2007 11:08 AM
a_tack
Oct 21, 2006 03:57 AM
