Grinding when reversing
Old Oct 23, 2011 | 12:36 AM
bunbun82's Avatar
bunbun82 is on a distinguished road
Default Grinding when reversing
Hi everyone! thanks for all the help before concerning my hubs, new issue i just encountered tonight. I went to start up my 2001 4x4 auto blazer and when i put it in reverse to back out of my parking stall, i experienced a loud grinding noise coming from the frontish area of the vehicle. Upon hearing this i put it back into drive and drove forward a little and proceeded to put it in reverse again, same grinding and almost crunching noise. I recently replaced the driver side hub assembly (dont know if this is relevant or not).
Does anyone have any possible insight as to what the noise might be? cv? brakes? tranny?
I am willing to look at anything and everything to try to diagnose the problem. Thank you in advance!!
Old Oct 23, 2011 | 09:06 AM
TZFBird's Avatar
TZFBird is on a distinguished road
I believe a grinding/crunching in reverse is the Sun Shell in the transmission breaking down. Unless something is really wrong with the front hub I'm guess it's strictly coincidental. You should either plan on rebuilding/replacing the transmission shortly or else have it checked in case I am wrong.
Old Oct 23, 2011 | 12:36 PM
98blazin's Avatar
98blazin is on a distinguished road
i had a grinding noise when back-up, that got worse and grinded all the time at low speeds. i asked my wife to back-up slowly while i walked on the side of the truck to see where it was commign from.
it was simply rust build-up on my rear rotor grinding on the galipers.
it took 5mins and it was free !
might be this, take a look thru your wheels and look to see if your rotors are rusted.
Old Oct 23, 2011 | 01:32 PM
bunbun82's Avatar
bah, so new update, when i drive in speeds over 50kph now i hear clunking and clinking going on in the front end, scares the bejesus outta me. there seems to be no rust buildup or anything like that on the rotors. i will however also take a look at the recently installed hub to make sure everything is ok too.
i just pray that i havent done excessive damage to my front axle for whatever reason...dreading the bills so bad.
Old Oct 23, 2011 | 01:36 PM
gatorboy44's Avatar
gatorboy44 is on a distinguished road
Yeah it's probably rust on your roders. That's what mine was
Old Oct 23, 2011 | 02:11 PM
bunbun82's Avatar
what would explain the clunking and clinking in the front end though when im driving forwards
Old Oct 23, 2011 | 06:05 PM
gatorboy44's Avatar
Is it when you turn?
DMenacer
Suspension Tech
Mar 12, 2011 08:29 PM
Harrison
Jul 22, 2009 01:17 PM
cherryred4x4
19
Feb 19, 2007 01:44 PM
lemon blazer
13
Jan 3, 2007 10:55 PM
Nadeaux
Nov 18, 2005 04:21 PM
