hard shifting going from 1st to 2nd
Old Sep 10, 2012 | 08:31 PM
scott530's Avatar
scott530 is on a distinguished road
This GM service bulliten might apply to your vehicle:
TSB # 01-07-30-023A
Harsh 1-2 Upshift, SES, MIL, or CEL Illuminated, DTC P1870 Set (Replace Valve Body)
1996 Buick Roadmaster
1996 Cadillac Fleetwood
1999-2000 Cadillac Escalade
1996-2000 Chevrolet Camaro, Corvette
1996-2000 Pontiac Firebird
1996-2000 Chevrolet and GMC Light Duty Truck Models
1996-2000 Oldsmobile Bravada
with 4L60-E Automatic Transmission (RPO M30)
Built Prior to January 15, 1999 (Julian Date 9015)
This bulletin is being revised to update the Parts Information.
Please discard Corporate Bulletin Number 01-07-30-023 (Section 07 -- Transmission/Transaxle).
Condition
Some customers may comment on a harsh 1-2 upshift and the Check Engine Light or Service Engine Soon indicator is illuminated.
Diagnosis
Typically, these vehicles will have been driven more than 32,000 km (20,000 mi) before this condition occurs.
The scan tool may show a DTC P1870 set as a history code.
A harsh 1-2 shift or DTC P1870, caused by wear in the control valve body, may be difficult to duplicate when the transmission temperature is below 93°C (200°F).
Cause
The condition may be due to wear in the control valve body. This wear occurs in the bore that contains the TCC isolator and regulator valves, and results in poor, or no, TCC apply.
Important
DTC P1870 is a type B code. The conditions for setting the P1870 DTC must occur on TWO CONSECUTIVE TRIPS (ignition cycles, with a drive cycle) before setting a P1870 history code.
When the conditions for setting DTC P1870 are met (first trip), the PCM commands maximum line pressure and harsh 1-2 shifts are the result.
This may result in a harsh 1-2 shift with no history code if the conditions for setting the DTC required for the second trip are not met, on two consecutive trips (Ignition cycles, with a drive cycle).
When the conditions for setting the DTC are met, on the second consecutive trip, a DTC P1870 is stored as a history code.
When the P1870 code is stored, the PCM will turn on the Service Engine Soon (SES), Check Engine Light (CEL), or Malfunction Indicator Lamp (MIL).
Correction
Install a control valve body with the revised TCC regulator and isolator valves. These valves are used in all transmissions produced after January 15, 1999 (Julian Date 9015), and all of the service parts currently available through GMSPO contain revised TCC regulator and isolator valves.
Important
If all of the following conditions are true, it is not necessary to rebuild the transmission or to replace additional transmission components beyond the control valve body.
Transmission operation is normal before the transmission reaches operating temperature, or before DTC P1870 is set (no slips, flares, or missing gears).
The torque converter is not blue or overheated.
The transmission fluid is not burned or has no burned odor.
The transmission fluid pan contains no abnormal debris (clutch material, bronze, brass, or metal fragments
PS. i have this issue on my truck i just bought. if fixed soon enough then no damage will be done. i called my local trans shop and they will fix my valve body for 100 bucks. if you let it go too long it will damage the torque converter and possibly the entire transmission
Old Sep 11, 2012 | 11:01 PM
kaleys1's Avatar
kaleys1 is on a distinguished road
i took it to my local tranny shop and it was the valve body thing and the tourqe converter, thanks for all the help guys
Old Apr 20, 2013 | 11:04 PM
Melrock83's Avatar
Melrock83 is on a distinguished road
Just to update..about a week after I commented on this thread my husband decided to pull his new boat with my blazer in OVERDRIVE and needless to say, the tranny sure didn't like it. Luckily, when I noticed the temp gauge rising I made him pull over and so it didn't do ne damage to the tranny or engine where it used the coolant/water to try and cool the tranny in turn causing my engine to start overheating. Then the next week following the boat issue, it broke down on my twice 1st time on Mon 2nd on Wed and I SOLD IT ON FRIDAY!! I was done, had put more than $3k in it in less than 2 yrs and was tired of getn stranded alllll the time. Hope u all have better luck with urs..and I am lookn for another blazer now, just not getn another 95 model PERIOD LOL
Daryllee
Mar 21, 2015 11:08 AM
99Legendary
Jun 13, 2012 06:27 AM
pbd3mon
Jan 17, 2012 08:50 AM
stepjl
Sep 25, 2010 12:17 AM
96jimmy4x4in
Oct 7, 2007 09:23 PM
