hard start and bad timing idle 94
Old Apr 22, 2008 | 08:20 PM
carpenter625's Avatar
carpenter625 is an unknown quantity at this point
Default hard start and bad timing idle 94
i bought a 94 ,4 dr,vortec 6, 4 days ago,it sat for a year before i bought it,77000 mi,i changed the oil and antifreeze,didn,t purge the radiator and next day temp gauge was stuck on hot,so i figured bad thermostat and changed that,to get to it ,you have to pull the rubber cowl off the air intake and that has a sensor in it,when i put it back together i had troubl starting it,it just kept turning over for maybe 45 sec and then it starts,when its running at idle it sounds way out of time and the exhaust stinks,it was running fine on the first day before i changed the antifreeze,i puged the radiator and changed the sensor in the air intake hose ,the temp guage is back to normal but the idle,starting ,timing problem remains
Old Apr 22, 2008 | 08:48 PM
WolfPack's Avatar
Default RE: hard start and bad timing idle 94
Coulda damaged the MAF sensor...unless that's the sensor you're talking about with the
Old Apr 22, 2008 | 08:59 PM
thanks for the reply, that sensor is the size of a fat pencil and about 1 and a half inches long,and it was $12,dont know what it's called
Old Apr 22, 2008 | 09:22 PM
Hanr3's Avatar
I believe that would be the air temp sensor.
When was the gas changed in teh tank?
Fill it up with 93 octane, add a can of seafoam to the tank and run it on that. Sounds to me like you have crap in your fuel system that you need to clean out.
Old Apr 22, 2008 | 09:59 PM
thanks ,i'll give that a try
Zach8846
Mar 11, 2014 10:43 AM
Kevin Gore
Dec 13, 2013 09:35 PM
MtownsFinest901
Jul 20, 2011 12:17 AM
jmatt07
Feb 19, 2011 08:39 PM
tbrincefield
Apr 15, 2008 09:29 PM
