Harmonic balancer help!!!!
Old May 24, 2020 | 12:19 PM
Dkarll88's Avatar
Dkarll88 is on a distinguished road
Default Harmonic balancer help!!!!
Working on a friends 98 jimmy 4x4. Lots of engine vibration. Noticed what looked like movement in harmonic balancer so i went to swap another i had from a 4.3 out of a blazer but when i lined them up the timing marks were off so we bought a new one to instal . After using installation tool to press it on i was able to just pull it back off by hand. Its the dorman balancer from autozone. Do i need a different balancer or a repair sleeve?? Thanks
Old May 24, 2020 | 04:19 PM
LesMyer's Avatar
Its fine. That the way mine was.
Old May 24, 2020 | 05:02 PM
Dkarll88's Avatar
What should the backspacing between balancer and crank be?
Old May 25, 2020 | 09:44 AM
LesMyer's Avatar
I don't understand your question.
Old May 26, 2020 | 03:07 PM
It sounds like hes asking how far the pulley is supposed to be from the engine block?
Old May 26, 2020 | 06:24 PM
Dkarll88's Avatar
No, sorry wording was odd i guess. I am wondering if the face of the crankshaft will sit flush with pulley or if there is backspacing and if so how much?
Old May 26, 2020 | 08:12 PM
LesMyer's Avatar
I'm pretty sure the front of the crank sits behind the face of the pulley and the bolt/washer tightens the rear of the balancer up against the crank timing gear/crank position sensor reluctor on the snout of the crankshaft behind the cover. The thickness of the reluctor/crank gear determines how far back the balancer goes and the big external bolt/washer simply holds it there - amount of "backspacing" would be irrelevant). Does there seem to be a problem?
Eluv123
Dec 22, 2019 04:00 PM
appliancguy
Nov 10, 2010 08:21 AM
mech cb
Mar 1, 2010 05:18 AM
thehustler211
Apr 14, 2009 06:06 PM
thehustler211
Apr 1, 2009 03:30 PM
