heater core fix
Old Feb 13, 2018 | 04:31 AM
honolulujoe's Avatar
honolulujoe is on a distinguished road
Default heater core fix
not sure if this is the right section to post this in but can't see a separate cooling section,.
had a fair bit of trouble getting the heater core to work, last thing you want at this time of year.
tried flushing with both water and compressed air which gave heat for a couple of mins once reconnected.
in the end I cheated, with some extra bits of tube and a couple of reducers I reversed the flow through the core. Result, lasting hot air.
so I shall leave it that way and see what happens then give the cooling system a really good clean out when it warms up.
Old Feb 13, 2018 | 04:33 PM
Glad you got it fixed. I can't imagine it being bad but my gut tells me to put it back as stock at the next opportunity. All that said, I can't give you a good reason for my suggestion. LOL
Old Feb 14, 2018 | 12:26 AM
I plan to put it back the right way after a good clean of the whole system.
figure a few weeks of running the other way will clean out whatever is stopping it working the right way
should be warmer then for rolling around on cold concrete under a truck
50lb_cat
Oct 3, 2017 03:40 PM
r_marczak_83
17
Mar 9, 2013 10:33 AM
swartlkk
Jul 15, 2011 01:47 PM
rdlyn
Engine & Internal
May 7, 2010 05:23 AM
Dodge Guy
Oct 25, 2006 08:48 AM
