HELP, 1990 Full Size Blazer No Injector Pulse
Old Aug 27, 2021 | 03:58 PM
bright6767's Avatar
bright6767 is on a distinguished road
Default HELP, 1990 Full Size Blazer No Injector Pulse
1990 Full Size Blazer No Injector Pulse.
I replaced the distributer, replaced the ECM and fuel pump is good. What next?
Old Aug 28, 2021 | 05:33 PM
How did you confirm you have a "no pulse" condition?
Old Aug 28, 2021 | 06:52 PM
Also, do you have power to the injectors? Did you check with a noid light?
Old Aug 29, 2021 | 03:32 PM
bright6767's Avatar
By troubleshooting it with the noid,
Old Aug 29, 2021 | 06:30 PM
GeorgeLG's Avatar
So you have power to the injector but no low side ECM pulse control/switching?
George
Old Aug 29, 2021 | 07:06 PM
bright6767's Avatar
Tell me more about he low side, never heard of it..
Old Aug 29, 2021 | 08:46 PM
GeorgeLG's Avatar
The way that fuel injectors work is to apply fused ignition power to one side of the injector coil and then take the other side and send it to the ECM which then controls the grounding of that side of the injector coil to create the duty cycle necessary for proper air fuel control. So the control of the injector is ground side switching by the ECM.
If you have improper fuel delivery then you either have:
Improper ignition power applied to the injector on the powered side
Improper ground side control of the injector by the ECM on the ground side
Bad wiring/connector
Bad injector
Fuel pressure issue
George
Old Aug 29, 2021 | 08:52 PM
GeorgeLG's Avatar
And if you have no ECM ground side switching the either the ECM is dead, there is a wiring/connector problem or there is a sensor input problem to the ECM for pulse timing like from a crankshaft position sensor.
George
Graveyard
May 24, 2016 11:33 AM
DR8699
Jul 11, 2013 12:14 PM
gantho
Apr 28, 2010 10:56 AM
RolingKCBlazer
Apr 21, 2009 01:08 AM
Blazin_1t_up
Tires and Wheels
Sep 13, 2008 12:37 PM
