help
![Unhappy](https://blazerforum.com/forum/images/icons/icon9.gif)
hello everyone, i have a 2001 chevy zr2 blazer. i am wondering what could be wrong with my truck, i have a rapid leak of antifreeze, along with poor acceleration and trouble starting, i recently had my distributer cap replaced, thinging that would help with the starting issues, i have had my fuel pump checked as well as my spark plugs, any ideas?
well i have yet to take a closer look at it yet, i am going to spend the day trying to diagnose what is actually the problem, but yeah like i said with the rapid leak i put close to a gallon of water and antifreeze in my radiator and within five hours it has almost completely leaked out
That is a serious leak. If you can't find any visual leaks then it sounds like the lower intake gasket failed. I hope you didn't let it over heat or you could have blown a head gasket! The lower isn't a hard job just time consuming.
Trouble starting - because antifreeze is being pushed into the cylinders after you shut it off.
What did the spark plugs look like when you changed them, what color, condition?
Does it smoke a bit when you start it after running to operating temp & shutting it off for awhile? If so then
![Icon That](https://blazerforum.com/forum/images/smilies/icon_that.gif)
