Help buying an engine
Old Feb 8, 2010 | 04:29 PM
K5corey's Avatar
K5corey is on a distinguished road
Default Help buying an engine
i am going to buy a 350 for my 84 k5 blazer. when i go to look at a motor what things should i look at or check for before i buy an engine?
Old Feb 8, 2010 | 09:04 PM
Hearing an engine run is always a plus.
Do you intend to find a motor ready to drop in or are you looking for a good rebuild candidate?
Old Feb 8, 2010 | 09:15 PM
Spectreblazer's Avatar
Banned
Spectreblazer is on a distinguished road
if everything is hooked up pop the radiator cap off before you start it. then start it. if you see bubbles don't buy (that means a bad head gasket). don't forget to put that top on. look for any physical damage as far as if it was in a wreck,
Old Feb 9, 2010 | 11:09 AM
K5corey's Avatar
Im looking for an engine that is close to being ready to drop in, mainly bottom end complete. But if i find a cheap block in good condition i wouldn't mind rebuilding it.
seriosbrad
Jul 16, 2014 10:28 PM
zedartwo
Jan 19, 2010 07:33 PM
USMC_KAK
Apr 11, 2009 08:58 PM
tjbmxrider
Apr 1, 2008 08:11 PM
88s10Blazer
Aug 25, 2006 02:44 PM
