Help with dropping front differential
Old Jan 18, 2018 | 07:17 AM
PAblazerboy2000's Avatar
PAblazerboy2000 is on a distinguished road
Unhappy Help with dropping front differential
So I am new here, and I was wonder if I could get some help form you guys and gals. I was wondering if you could tell me if its the same to drop a front diff in an s10 as it is in a full size chevy? Do I have to take out the front axles or can I just drop the diff by its self? Thank you....
Old Jan 19, 2018 | 08:20 AM
El_Beautor's Avatar
As far as I know you have to remove the driver side upper control arm to drop the diff because one of the diff support bolts is inside the frame behind the UCA, but you have to remove the CV axles anyways, so you're 3/4 of the way there already. Be sure to carefully mark the angle of the eccentric washers on the upper control arm before you remove them. They are part of your steering alignment so you'll want to put them back in the exact same spot when you reassemble everything. You may also have to loosen the bolts on the steering box to move the drag link forward enough for the diff to drop out.
Old Jan 21, 2018 | 02:51 PM
Thank you for you in put, it is much appreciated
ChromeJerome
May 15, 2013 11:16 PM
Drew4711
Oct 6, 2012 12:47 PM
972DRBLAZER
Oct 14, 2009 06:11 AM
98BlazerLT4x4
Mar 4, 2008 06:00 PM
speeddemon560
Suspension Tech
Feb 6, 2007 04:18 PM
