help having temp problems
Old Mar 18, 2014 | 05:58 PM
supermario28's Avatar
supermario28 is on a distinguished road
Default help having temp problems
i have a 1995 blazer 4wd was driving and heater hose plastic tube connecting hose so i replaced it with a new hose and antifreeze didn't notice i used dex-cool antifreeze and now the temp goes from 1/2 to 3/4 on the temp back and forth should i drain it and use the regular? Or what could it be? air in the system or dex cool with reg antifreeze does that to my car? it has more of the reg antifreeze and just like one gallon of dex-cool. Help oh never had temp problems till this has happened
Old Mar 18, 2014 | 07:34 PM
chris015's Avatar
chances are its a coincidence.
flush the coolant system,or have someone do it. you dont want dexcool with green. **** happens.
as for the temp....probally a bad thermostat. get a 195 thermostat. have someone else do it if you arent sure.
Old Mar 19, 2014 | 01:57 PM
if it was a bad thermostat the bottom hose would be hot right?
bat6180
Nov 14, 2012 02:39 PM
lynnboy021
Feb 11, 2011 08:46 PM
zakm0n
Jan 9, 2011 07:31 PM
xbriguyx
Jan 28, 2010 04:56 PM
blazer_geezer
Apr 27, 2007 01:55 AM
