Help! High Pitch Squeal!!
Old Sep 12, 2012 | 04:42 PM
Greg828's Avatar
Greg828 is on a distinguished road
Exclamation Help! High Pitch Squeal!!
Well first off i have a 1993 Fullsize Blazer with 5.7L 350, with a 5 speed. When i start it up it runs fine but once she warms up a little bit it develops a really High pitched and loud squeal, but the squeal goes away when i give it a little bit of gas. The noise seems to be coming from the top of the engine in one of the pully housings, a friend said that it sounded like a bad throwout bearing but then noticed it was near the top so if anyone can help me with what may be causing the problem id greatly appreciate it Thanks Greg
Old Sep 12, 2012 | 04:52 PM
richphotos's Avatar
Tensioner pulley?
Old Dec 2, 2012 | 10:10 AM
Jim Bailey's Avatar
Jim Bailey is on a distinguished road
Default high pitch squeal
does it have ac? sometimes the bearing noise will be lower with a load. try some oil behine the ac clutch
Old Dec 2, 2012 | 10:22 AM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
IM banking on one of the accesory pully`s or bearings making the noise.My truck does the samething till I spray all the pullings and bearing ares with solcon spray.Then its quiet for a while and will start back again usualy if I go through alot of water.
Old Dec 2, 2012 | 10:58 AM
chris015's Avatar
All you have to do is pull off the belt,and spin the pulleys,if they squeak or sound rough replace it. While the belt is off start her up for a few seconds (make sure nothing is sitting on the fan) If shes still making the noise its nothing on the belt. If shes quiet,then whalla find which one is bad.
kelly2
May 8, 2015 09:10 PM
swanman35
Jan 11, 2013 04:18 PM
kuojo
Mar 28, 2012 07:22 PM
GloryImSaved
Jul 14, 2009 06:26 PM
chevyblazer2008
Jan 8, 2008 05:44 PM
