Help me before I KILL IT !!!
What IT is 94 s10 Blazer LT 4.3 CPI Vortec (yes I,m sure). What IT is doing. IT will not start hot or cold. But if I prime it with gas into the pleum it starts right up and will run and drive untill I shut it off. Then it will only start if primed. NO prime no start. Prime it and it starts and runs. Also I get no codes throwen while it runs. Any thoughts?
check the fuel pressure guage? possibility
The fuel pump is probably supplying enough pressure to keep the engine running, but not enough to get it started.
chris015
06-03-2011 11:37 AM
yarinzim
09-13-2010 09:37 AM
darque
03-27-2010 01:57 AM
oddbirdman
12-17-2007 05:46 PM
