Hesitation problems
Old Apr 3, 2012 | 06:31 AM
DaddysBlazer's Avatar
DaddysBlazer is an unknown quantity at this point
Exclamation Hesitation problems
I checked my spark plugs yesterday and they were filed out with a small amound of oil residue on them. So I changed all the spark plugs yesterday to AC Delco plugs and it seem to make getting up to speed worse. Also, I checked the oil yesterday and some dummy from the shop put 5 quarts of oil in it, it was way past the full line by alot! So i drained 1/2 a quart because my truck is supposed to have 4.5 quarts in it. Maybe that has something to do with the hesitation as well. Any ideas?
Old Apr 3, 2012 | 12:56 PM
50lb_cat's Avatar
Did you gap the plugs? What was the truck doing before the plug swap?
Old Apr 3, 2012 | 04:15 PM
hesitating slightly
Old Apr 3, 2012 | 07:18 PM
50lb_cat's Avatar
Next thing to do would be clean your maf sensor. How old is your cap and rotor?
Old Apr 20, 2012 | 08:05 PM
brand new ACDelco
Old Apr 21, 2012 | 12:34 AM
50lb_cat's Avatar
You can also disconnect the maf sensor and drive it to see if it helps. If it does it needs cleaned.
p.o.s.blazer420
Nov 19, 2012 07:07 PM
Brilen33
Dec 1, 2011 02:07 PM
sav25age
Sep 21, 2009 11:50 AM
upblazer95
Apr 4, 2009 08:27 PM
jp5162
Mar 1, 2005 10:11 PM
