hesitation,stalling,and idling problems..
Old Nov 17, 2012 | 12:21 AM
p.o.s.blazer420's Avatar
p.o.s.blazer420 is on a distinguished road
okay so heres the deal,my 97 blazer stalls when its not warmed up,the hesitation varies from very bad every stop light to every so often,and idling is what has me super confused it acts like it wants to accelerate with my foot completely on the brake.so i have to put it neutral at a stop if its for more than a minute or so...i replaced the vac line to the maf sensor and new plugs distributor less than 500 miles ago...i was thinking fuel injectors maybe but i have the spider injector which cost over 300 please help...i hate to spend that money and it not fix the problem
if the two plugs are connected on what i want to call the mass air flow sensor,you know the tube that runs to my throttle body from the air fliter lol not mechanic just a 21 year old trying to fix his truck and learn..so i could be worng but yeah if they are plugged in everytime i hit the gas it stalls..thanks hope to here some feed back
Last edited by rriddle3; Nov 17, 2012 at 10:35 AM. Reason: COMBINING CONSECUTIVE POSTS
Old Nov 17, 2012 | 06:52 AM
AndrewO1991's Avatar
AndrewO1991 is on a distinguished road
sounds like a vacuum leak. Does it act up when you hit the brakes? or just all the time and doesnt matter. The fuel injector problem usually just casues it to bog down. You ID'ed the MAF well, it tells how much air is entering the engine. If ANY air enters the engine AFTER this component it will casue it to idle up and not run right. Could be a vacuum leak or an open spot in the intake plenum behind the MAF to the throttle body. Make sure it's seated on the throttle body good.
Old Nov 17, 2012 | 10:30 AM
50lb_cat's Avatar
+1, could also be a dirty idle air control valve. Check out the DIY tech section to see how to remove and clean it and the throttle body.
Old Nov 18, 2012 | 01:50 PM
Thanks gonna clean it today see what happens thanks
Old Nov 19, 2012 | 05:49 PM
no vacuum leaks,cleaned the iac valve today,new spark plugs,and clean the egr valve,then i plugged my maf sensor back in it would drive at all,it would start up then as soon as i shifted in gear it stalled everytime,i unplugged it,then it right with only the hesitation didnt stall at all on the way home from where i was working on my truck at..so no idle problems for the most part with the maf sensor unplugged..but still have hesitation?im very confused.and my oil pressure gauge is all over the place...
Old Nov 19, 2012 | 06:33 PM
Diaita's Avatar
crank case vent on the back of the air plenum. ive forgot to put mine on a couple times and it does close to what you describe.
Old Nov 19, 2012 | 07:07 PM
50lb_cat's Avatar
Also, have you cleaned the MAF with MAF spray cleaner? Next I would do a fuel pressure and leakdown test.
Don476
Mar 16, 2015 09:58 PM
Squad-6
May 21, 2011 02:23 AM
fiXXitup
Sep 2, 2009 12:47 AM
Boyer2011
Apr 5, 2009 08:07 PM
eskylar!59
19
Dec 23, 2008 09:13 PM
