High Idle
When i bought my 87' S-10 Blazer the guy told me he had removed a vacuum line from the truck for his car.. So i get the truck started, and it idles at about 1500-2000 rpms. I've been looking for where he took the line out but i can find it and i asked him and he couldn't remember. so does anyone know where the line would be?? Any suggestions will be great..
Without a wild guess....
Just feel/look/listen around the intake for a vacuum leak or open vacuum port on the throttle body or intake.
From the sounds of it, you have a large leak that shouldn't be too difficult to locate.
I know this is a old post but i found the leak that was making the noise, it was a vacumm line that broke in half behind the throttle body that goes to the transfer case. I fixed it.. But the engine still idles at 1500-2000 rpm. I don't think you're able to adjust the idle on fuel injected right?
any ideas anyone??
Definitely sounds like you still have a rather large vacuum leak. I would start by disconnecting all of the vacuum lines to the engine and plugging them. See if the problem persists. This includes blocking off the line that runs to the brake booster.
mcdevin1973
Oct 5, 2014 02:52 PM
midnightryder
Dec 29, 2009 02:43 PM
