hose will not budge!
a hose behind the a/c bracket, which i think is a heater hose will not want to budge at all! i am using the right size wrench and all i am doing is rounding the edges. i stopped messing with it for now, but this is the only hose that i need to remove to remove the lower intake manifold. if there isnt a way of removing it(which i will find out later), how much does this hose cost? and whats the purpose. it seems to lead to the bottom of the block.
RE: hose will not budge!
If you're attempting this repair, you're probably pretty good with tools, but just in an effort to be helpful, if you can get to this bolt with a 5-point socket, verses a 10point socket or open end wrench, it'll give you more contact area and be much less likely to round. Might help someone out there anyway.
I believe he is talking about the EGR supply tube. You may want to try some penetrating oil on the connection. You may also want to try some heat on the lower intake manifold, cooling the fitting with some penetrating oil.
yea. i looked up egr supply tube online and im pretty sure thats what it is. and i tried heat and penetrating oil. the nut is just getting worse. if worst comes to worst i think im gonna have too. but it looks pretty difficult getting to the other end...
and i cant seem to find this hose anywhere. where would i be able to order something like this?
Wrench or socket?
6 point or 12 point?
What size bolt?
Heater hose would run into the firewall. If it is the heater hose your local autoparts store will sell you the hose. Its generally a bulk item they carry in stock on a roll in the back. Or you could order a new one from your preferred GM dealer parts center.
Are you coming at this boltfrom the top or side?
Vise Grips are amazing tools if you can get them on there. crank the crap out of them and use two hands to secure it to the bolt. Once you break the bolt free use a normal tool.
What size bolt?
My Blazer is the usuall rust from top to bottom, front to back andPB Blaster helped me a million times. just be patient and use it more than once. wrap a rag around it and soak it over night.
Tim, it is the EGR supply tube that he is talking about and this can be a pain. I am not sure I would advise the use of vice grips as it is possible to squash the large flare nut style connection. If you do this, you should expect to replace the EGR supply tube. And as already surmised, it is very fun to get at down on the exhaust manifold.
er0ck273
07-04-2013 01:36 PM
xtrmblazn01
17
04-11-2012 11:32 PM
