Hot
Old Jun 27, 2011 | 06:53 PM
throttlerat's Avatar
throttlerat is on a distinguished road
Default Hot
I have a 1995 Blazer with 240k on it. I have noticed recently that when I drive around town, stop and go traffic, with ac on, because its like 100 degrees here in Orlando, when I stop to shop or run errands, then get back in to start her up, it hesitates, than kicks over. When I start her cold, she starts right up. It seems to only happen when I have been running it for awhile. Aside from that issue, I am debating getting a newer car, but at this point I have replaced some major parts. The gas consumption is killing me with this car! I have had it 11 years and we have been all over the country a few times..not sure if I should just run it into the ground or get something better on gas....?
Old Jun 27, 2011 | 08:52 PM
Could be a number of different things. Heat soak can affect ignition components (coil, ignition control module, etc). You may have a fuel leak inside the plenum that is affecting both hot starting and your fuel mileage.
stevenhousden
Jul 6, 2014 05:56 PM
Mandrwj
Apr 10, 2011 07:32 PM
88_s10
Jan 15, 2011 05:04 PM
ravenhurst
15
Apr 26, 2009 07:53 AM
Swblazer
May 25, 2006 01:18 AM
