How can you tell if ECM is Bad? at the end of ideas
Old Dec 19, 2018 | 10:56 PM
Bayla's Avatar
Bayla is on a distinguished road
Default How can you tell if ECM is Bad? at the end of ideas
I have a 1995 with 4.3 vortex that will crank but not start...I have replaced, Mass air, MAP, cam position, crank position, distributor, rotter, wires, plugs, O2 sensor, Fuel Pump, Fuel Filter......has great compression...I'm out of ideas....could use some advise from someone smarter than me
Old Dec 20, 2018 | 07:13 AM
LesMyer's Avatar
#1: Have you had the distributor out? if so, was that when the engine stopped running? #2 Do you have spark at the coil while cranking? #3 Will engine start if you pour a little gas down the throttle body?
Old Dec 21, 2018 | 11:48 AM
Bayla's Avatar
Thanks you for replying..You won’t believe what it was!! ECM computer connector worked its way loose!! I never would have found it..got desperate though might need a new ECM I’m new to Blazerforum and a new owner of 1995 GMC Jimmy 4x4....I bought it for $1,500..145,000 miles..Suposed to be a backup truck ...now I fell in love with it trying to restore..I have lots of questions lol thanks again
vanwinkle76
Mar 14, 2015 08:31 PM
folkenson
May 29, 2014 04:29 PM
70Camaroman
Jul 31, 2013 09:27 AM
moe_23
Mar 7, 2012 03:09 PM
89blazer26
Feb 14, 2011 08:28 PM
