how to change tranny fluid, filter and pan
Old Nov 22, 2011 | 05:41 PM
darknight's Avatar
darknight is on a distinguished road
Default how to change tranny fluid, filter and pan
how would i go about changing tranny fluid, filter and pan on my 2001 blazer
Old Nov 22, 2011 | 06:04 PM
Little Roober's Avatar
Little Roober is on a distinguished road
Go under truck, use correct size socket (for whatever reason 13mm comes to mind??) remove pan, let drain, remove filter, replace filter, replace pan, fill.
Old Nov 22, 2011 | 06:09 PM
DaddysBlazer's Avatar
DaddysBlazer is an unknown quantity at this point
Man its not hard at all, first you have to take out about 12 bolts 2 of them are connected to your shifting cable , and those you will have to get at with a gear wrench or open end box wrench. I want to say 11 or 12 millimeter, then be ready to catch some tranny fluid because your going to lose some as your lowering the pan. Then you will pull the filter out just by wiggling it and pulling down. there is a rudder or soft plastic washer at the top of that filter and sometimes they don't come out with the filter so make sure you see some kind of washer when you pull it out. Installing the new one you'll see what washer I'm talking about there will be a new one in the box very very important. Anyway then you will notice inside the tranny pan that there is a flat magnet probably with some gooey stuff on it, clean it off, and put it back inside the little indention in the pan you took it out of then just simply re'install the pan leaving the two hardest bolts for last fill with new tranny fluid and go do some donuts. ya right I hope this helped seriously
Old Nov 23, 2011 | 05:30 PM
darknight's Avatar
cool sound pretty easy, thanks for all the info.... just need to know how much fluid is gonna be coming my way thats all...
Old Nov 24, 2011 | 07:02 PM
Not much If your good at balanceing stuff,
BrinkDiamond
Mar 2, 2014 03:50 PM
LannyL81
Feb 27, 2012 11:58 AM
boondoggle
Dec 15, 2010 08:36 PM
DaleA
Jan 13, 2009 08:50 PM
BigJoeFord
Jul 29, 2007 03:21 PM
