Oil leak in 2000 Jimmy. Video included.
Old Nov 14, 2011 | 12:16 AM
iamchevyman5's Avatar
iamchevyman5 is an unknown quantity at this point
Default Oil leak in 2000 Jimmy. Video included.
Here's the video. . .
jimmy - YouTube
Probably unrelated because I think the oil was also leaking "prior to," but I recently changed the oil.
Also, does anyone have any tips for fabricating a new underbody cover?
thanks,
Dan
Old Nov 14, 2011 | 01:46 AM
tallhorseman's Avatar
tallhorseman is on a distinguished road
The first thing I would check is valve cover gaskets.
Old Nov 14, 2011 | 02:57 AM
After doing some research I'm thinking it's actually the oil cooler lines. Here's a link of a pretty good work-up on how to replace them, and his symptoms and leak location are synonymous with mine.
How To Fix An Oil Leak: Replacing Oil Cooler Lines In A 1999 GMC Jimmy
I also found a good write-up on how to make a modification to relocate the oil lines. Let me know what you think of this. I'm deciding which would be the better repair&replace action.
Remote Oil Lines Modification - Automotive Forums .com Car Chat
Old Nov 14, 2011 | 05:41 PM
Default Oil Lines
Actually the oil cooling lines terminate into an adapter that bolts to the side of the engine... It does in my truck at least. Behind said adapter is a gasket or two. Check there for your leak first. They are notorious for leaking.
Old Nov 14, 2011 | 06:02 PM
Here's an example. If the gaskets were going bad in the first place you might have worsened the leak when you replaced the oil filter. Check this to see if it helps.
how to change oil filter line on engine side. 97 s10 blazer - JustAnswer
Old Nov 24, 2011 | 02:52 AM
Anxious to here where the leak was coming from. Post it
Old Nov 25, 2011 | 05:07 PM
the leak was coming from the oil cooler lines. Replaced them and I still haven't finished the job. There's a more current thread on this site about my on-going problems replacing the lines. It can be found in this same engine&transmission section under the title "Car Emergency: oil cooler leak. Video included."
Thanks,
Dan
konfettix13
Mar 23, 2014 08:56 PM
iamchevyman5
Nov 23, 2011 06:14 PM
iamchevyman5
Feb 9, 2011 07:17 AM
musclecar70sfan
Jan 27, 2010 03:29 PM
Smoked
Jun 23, 2008 02:42 PM
