How do I find the part # for my transfer case
Old Dec 19, 2008 | 12:33 PM
PowerT39's Avatar
PowerT39 is an unknown quantity at this point
Default How do I find the part # for my transfer case
I have a blazer 2000, 2 door, 4WD, Electronic transfer case. I was told that I need to replace the transfer case. How and where can I find the part number w/o using a mechanic. Thanks.
Old Dec 19, 2008 | 12:52 PM
Default RE: How do I find the part # for my transfer case
Do you have the Auto4wd option?
What makes you think that the entire transfer case needs to be replaced? What is it doing?
Old Dec 19, 2008 | 01:26 PM
PowerT39's Avatar
I have the electronic one (manual), the noise coming from the driveline was getting worse, I was first told it was the rear diff, then aamco thought that it was the right front wheel bearing. I changed the wheel bearing, the problem didn't go away. Finally a transmission mechanic went over the powertrain, transmission and diff are fine, he then checked the transfer case's oil level, it was completely dry, we added oil but no changes, he believes that the damage has been done and suggested that I change the whole thing, voila. I am trying to save money by getting a used part from a junk yard but I need the part no. and I have been searching online for days. It would be nice to know how to go about it (he told me to look under the chassis but it s confusing and not practical).
Old Dec 19, 2008 | 01:30 PM
If you have the three button switch in the dash, then you have the NP233 transfer case. Just look for another s-series vehicle of the same year range that also has the three button switch in the dash. The transfer case will also have an aluminum identification tag on the back of it near the rear axle output housing. It will be riveted on and should include the same information on it.
Old Dec 19, 2008 | 01:36 PM
PowerT39's Avatar
Many thanks.
Old Dec 19, 2008 | 07:23 PM
WolfPack's Avatar
Nows a good time to put an Atlas II in there
Old Dec 19, 2008 | 09:23 PM
Hanr3's Avatar
ORIGINAL: WolfPack
Ka-ching $$$$$
Flyfishen
Jun 18, 2019 11:22 AM
SteveBroad
Oct 6, 2016 08:29 PM
bensaintonge
Dec 3, 2013 08:14 AM
spider21
Nov 17, 2011 06:27 PM
Marcin
Oct 14, 2006 06:09 PM
