Transfer case oil seal part number needed
Old Jan 6, 2012 | 06:56 PM
SteveBroad's Avatar
SteveBroad is on a distinguished road
Default Transfer case oil seal part number needed
Hi. The output shaft oil seal on the transfer case (where the prop shaft/drive shaft comes out) is leaking. Does anyone know the part number for the seal? Vehicle is a 1999 Blazer LT 4.3l. Local importer (I am in the UK) wants $53 for one!
Old Jan 6, 2012 | 11:11 PM
Verno's Avatar
Verno will become famous soon enough
This is from Rockauto Webpage.
1999 CHEVROLET BLAZER 4.3L V6 : Transfer Case : Output Shaft Seal Wiki Price
SKF Part # 11778 {#12544075} Outside diameter=2.4530"; Width=.500"; Shaft=1.177"; Bore=2.448IN
w/New Process 231C & 233C; Front
Choose:
$2.33
Add Part
TIMKEN Part # 5200
AWD; N.P. 231, 233; Seal & Bushing Kit; Rear
4WD; N.P. 231, 233; Seal & Bushing Kit; Rear
Choose:
$2.75
Add Part
TIMKEN Part # 4813V Shaft Size: 1.178"; Housing Bore: 2.447"; Seal Width: 0.5"; Seal Outside Dia: 2.452"; Seal Lip Material: FluoroElastomer; Housing Material: Steel; Max Temp: 400°F; Min Temp: -40°F; Seal Type: 860; Press Fit
AWD; N.P. 231, 233; Front
4WD; N.P. 231, 233; Front
AWD; N.P. 233C; Front
4WD; N.P. 233C; Front
$3.27
Add Part
NATIONAL Part # 4813V Oil Seal; Fluoroelastomer Seal, Clockwise-Spiral Lip Design, Shaft Size=1.178", Housing Bore=2.447, Outer Diameter=2.452, Width=0.5in
Front; New Process 233C 2 Spd. Part Time Transfer Case
$4.54
Add Part
TIMKEN Part # 4333N
AWD; N.P. 231, 233; Rear
4WD; N.P. 233C; Rear
4WD; N.P. 231, 233; Rear
AWD; N.P. 233C; Rear
Choose:
$5.15
Add Part
NATIONAL Part # 710668 Oil Seal
Front; New Process 136C 1 Spd. Full Time Transfer Case
Front; New Process 236C 2 Spd. Full Time Transfer Case
$9.42
Add Part
SKF Part # 18687 {Click Info Link for Alternate/OEM Part Numbers} Outside diameter=2.7540"; Bore=2.750"; Width=1.370"; Shaft=1.875IN
Extension; w/Borg Warner 4472; Rear
Choose:
$10.58
Add Part
NATIONAL Part # 4333N Oil Seal; Polyacrylate Seal, Counter-Clockwise-Spiral Design, Shaft Size=1.886", Housing Bore=2.699, Outer Diameter=2.704, Flange Outer Diameter=3.05", Width=0.35in
Rear; New Process 233C 2 Spd. Part Time Transfer Case
$11.07
Add Part
SKF Part # 18860 {#15661460, 8677463} Width=.350"; Shaft=1.886"; Outside diameter=2.7000"; Bore=2.690IN
w/New Process 231C & 233C; Rear
$13.18
Add Part
ACDELCO Part # 15661460
SEAL,TRFER CASE RR OUTPUT SHF TYPE 233C; 4 WHEEL DRIVE; w/ELEK SHFT TRFER CASE(NP1); BOOTED,1.5" DEEP
$15.40
Add Part
NATIONAL Part # 710496 Oil Seal; Fluoroelastomer Seal, Shaft Size=1.89",Outer Diameter=2.697, Width=0.433in
Rear; New Process 136C 1 Spd. Full Time Transfer Case
Rear; New Process 236C 2 Spd. Full Time Transfer Case
$16.42
Add Part
TIMKEN Part # 710496 1.875 in. Shaft Size; 2.684 in. Bore; 2.705 in. Outer Diam; 1.403 in. Width
AWD; N.P. 136C; Rear
4WD; N.P. 236C; Rear
AWD; N.P. 236C; Rear
4WD; N.P. 136C; Rear
$17.89
Add Part
SKF Part # 19317 {#12547638} Width=.433"; Shaft=1.890"; Outside diameter=2.7070"; Bore=2.697IN
New Process 236; Rear; 4WD
Old Jan 6, 2012 | 11:58 PM
Gale's Avatar
Gale is an unknown quantity at this point
On parts that were never built by GM seals are not hard to find here in the States but for some going to a local GM dealer is the way to go here.
When with the GM rear main seal because of higher quality than FelPro and this morning had to pick up the rear transmission seal at the dealership parts department and is was the same as the OEM seal pulled.
After market seals sometimes are not the quality of OEM.
Hey in the UK are there a lot of Blazers on the road. Here the S10 line has a high population in part because they keep running.
Old Jan 7, 2012 | 05:55 AM
SteveBroad's Avatar
No, very few. I have had my beastie for over 2 years and have only seen one other! This is good and bad. Good in that I am not driving something everyone else is but bad because of the lack of spares. To that end I bought a damaged LT as my private spares store :-)
Old Jan 7, 2012 | 05:57 AM
SteveBroad's Avatar
Choose:
$2.33
Add Part
TIMKEN Part # 5200
Choose:
$2.75
Add Part
$3.27
Add Part
$4.54
Add Part
TIMKEN Part # 4333N
Choose:
$5.15
Add Part
$9.42
Add Part
Choose:
$10.58
Add Part
$11.07
Add Part
$13.18
Add Part
$15.40
Add Part
$16.42
Add Part
$17.89
Add Part
Great, thanks for the every quick response. I will take this list to my local bearing store on Monday.
Old Jan 7, 2012 | 07:56 AM
SteveBroad's Avatar
Replied twice by mistake so, as I can't see how to delete message, I have deleted the text :-)
Old Oct 6, 2016 | 08:29 PM
Transman304's Avatar
Here you go
Choose:
$2.33
Add Part
TIMKEN Part # 5200
Choose:
$2.75
Add Part
$3.27
Add Part
$4.54
Add Part
TIMKEN Part # 4333N
Choose:
$5.15
Add Part
$9.42
Add Part
Choose:
$10.58
Add Part
$11.07
Add Part
$13.18
Add Part
$15.40
Add Part
$16.42
Add Part
$17.89
Add Part
Flyfishen
Jun 18, 2019 11:22 AM
spider21
Nov 17, 2011 06:27 PM
ChevyHick01
Jun 18, 2011 06:27 AM
GLBL WMR
Nov 14, 2009 05:54 PM
doodad69
Dec 1, 2008 01:44 PM
