How do you adjust rocker arms?
Old Jan 1, 2011 | 06:08 PM
2000TAHOEMAN's Avatar
2000TAHOEMAN is on a distinguished road
Default How do you adjust rocker arms?
I have a 1976 Chevy K5 Blazer that I just did a head job on it. I need to know what's the easiest way to adjust the rocker arms if I can't get the crank to turn?
Old Jan 1, 2011 | 08:14 PM
AJBert's Avatar
If I'm not mistake, you can only adjust the rocker arms while the engine is running. There is a pre-set torque to them before starting the engine up but they must be set while the eninge is running.
And if you can't get the engine to turn over, you have bigger problems than setting the valve lash.
Old Jan 1, 2011 | 08:27 PM
I'll second the "bigger problems" comment.
You can set them without the engine running, but you must rotate the engine to be able to set the initial tension on the lifter while it is on the base circle of the cam.
neal
Engine & Internal
21
Jan 6, 2015 11:19 AM
Pyro_fighter
Nov 13, 2012 03:23 PM
MikeRo
Apr 6, 2012 09:08 PM
magnum434
Sep 21, 2009 10:47 AM
Baja Blazer 85
Engine & Internal
Jun 1, 2009 08:55 AM
