How much play in rear driveshaft is acceptable?
Old Apr 14, 2020 | 07:42 AM
Husk's Avatar
Husk is on a distinguished road
Default How much play in rear driveshaft is acceptable?
I have a 2004 4WD Blazer which has leaked trans fluid into the transfer case via a bad seal. I drained out 2.5 quarts excess fluid from the transfer case. When I was under the vehicle I grabbed the rear driveshaft and to my somewhat surprise I was able to rotate it some. The u-joints seem tight and it appears the slop is within the transfer case. Could this be gears in the transfer case wearing? The vehicle has 200,000 miles on it but I have owned it for only the past 20,000 miles. I believe it is the original transfer case. I don't know how long the seal in the transfer case has been leaking trans fluid but could the excess fluid have caused damage to the transfer case?
Bolbol
Mar 30, 2016 03:39 PM
fslobodecki@yahoo.com
Jan 14, 2012 06:10 PM
motoart1
Apr 12, 2011 07:09 PM
raymondrobinson
Mar 27, 2010 08:09 AM
mikes87k5
May 4, 2009 07:15 AM
