humming noise gas pedal
Old Jul 26, 2013 | 04:02 PM
Ashblack59's Avatar
Ashblack59 is on a distinguished road
Default humming noise gas pedal
There is a humming noise coming from my gas pedal it seems to go away when i press the pedal. It is constantly humming and vibrating. i need suggestions on where to start. ThaNKS
Old Jul 26, 2013 | 04:06 PM
Ashblack59's Avatar
Its a 96 chevy blazer vortec 4.3
Old Jul 27, 2013 | 07:32 PM
Ashblack59's Avatar
it also started stalling when at a complete stop any suggestions would be helpful thanks
Old Jul 27, 2013 | 07:36 PM
chris015's Avatar
is it like a fuel pump hum? My friend has a noise in the pedal and it was the wheel bearings echoing into it. if its stalling,check fuel pressure with a fuel kit (at autozone etc,its free with retail deposit,ask about the loan program) its gotta be 60 at key on,and hold for 10 min.
Old Jul 28, 2013 | 01:09 PM
Ashblack59's Avatar
It is not like the him of the fuel pump thanks fire the suggestion the serpentine belt came off the other day but is still intact it really didn't start humming that bad until a couple days after it was put back on could it possibly have something to do with that
Old Jul 28, 2013 | 01:10 PM
Ashblack59's Avatar
stupid auto correct
Old Jul 30, 2013 | 06:15 PM
abig84's Avatar
check your throttle cable under the hood to make sure its not resting on anything. ive actually seen them rest against the pcv valve which will cause a humming noise inside the truck
zstudna
May 29, 2012 06:06 PM
NYCJUDGE
Aug 28, 2011 04:35 PM
ChrisAttebery
Jul 3, 2007 12:31 PM
drperry
Performance & Brainstorming
Apr 26, 2007 08:48 PM
nofear17bmx
Dec 31, 2006 09:45 PM
