I need help!
Old Dec 21, 2018 | 05:20 PM
Samantha Huxtable's Avatar
Samantha Huxtable is on a distinguished road
Default I need help!
I have a 97 blazer.
a while back we replaced the fuel pump and spider injector. Car has been running fine, since recently. So when I go to start it doesn't always turn over. Most the time i have to push the gas to get it started and I just started hearing knocking noises?
I read some forms that say the knocking happens with the high mileage. But it still makes me nervous. I do think it's about time for an oil change and a basic turn up. What else Could be wrong?
Old Dec 21, 2018 | 05:40 PM
Under what conditions do you hear knocking sounds? When cranking? At the same speed as the motor? Can you describe the sounds?
Oil changes should be a regular maintenance item. Have you checked the oil? What does it look like?
Old Dec 21, 2018 | 05:43 PM
go chevy's Avatar
Where is the "knocking" noises coming from? If it is the engine I strongly recommend checking the oil level and getting a oil change before you throw a rod! I would also suggest using "high mileage oil" or using synthetic motor oil, which costs more than high mileage oil...
Old Dec 21, 2018 | 05:44 PM
While driving it knocks in the engine by the glove department. Its not loud, more like a faint knocking. It doesn't always knock, it comes and it goes.
oil is fine. It's just about that time to do an oil change.
Old Dec 21, 2018 | 05:59 PM
go chevy's Avatar
Just by chance, are you hearing or feeling a slight vibration from the front passenger wheel area? If so you might need a new wheel hub assembly. I just had mine replaced. Mine was making a kinda "rubbing sound"...
Old Dec 21, 2018 | 06:09 PM
No vibrations in the car. But that's good to know just in case it starts
Old Dec 21, 2018 | 06:32 PM
El_Beautor's Avatar
If it is engine knock, that is a big concern that should be address. If it is something else you'll still want to address it, but it is less of a panic.
If the knocking corresponds with bumps on the road, and sounds more like a metallic tap/thump it could also be your hood hinge. There was a tech bulletin for them rattling.
Old Dec 22, 2018 | 05:49 PM
go chevy's Avatar
Might not be nothing but are all of your gauges on the dash working properly? Reason I ask is I kept blowing the #15 10amp fuse on my 98 4x4. I just had the front passenger side wheel hub replaced and all is fine now, no more rubbing kinda sound and no more blown fuses lol...
Old Dec 22, 2018 | 05:58 PM
A code will come up but it goes away pretty fast. I'm not really sure what code cause when we've try checking it it turns off.
Old Dec 22, 2018 | 11:34 PM
odat's Avatar
Sorry - never mind - I found the other post after I posted here and posted there so I wasn't changing the subject
youngsm1980
Dec 9, 2023 05:31 PM
iceblue068
Jul 30, 2016 03:13 PM
dano440
40
Apr 22, 2012 11:34 AM
Jharper
Dec 11, 2007 06:12 PM
gohan69
Sep 8, 2007 06:49 PM
