I think I did it wrong
Old Mar 13, 2011 | 06:24 PM
fammyman's Avatar
fammyman is on a distinguished road
Default I think I did it wrong
So I got some spray sea foam. It says to spray it at the throttle plate. Well on my 98 blazer this cant be accomplished by putting the straw in the intake boot. So I folded the straw under the coverthing that goes over the throttlw body reved engine and sprayed per instructions. Well the engine never bogged and it never did make a smoke bomb I always here about ? Sooooo where did I mess up ?
Old Mar 13, 2011 | 06:38 PM
blazinloud's Avatar
has to go in the oil to make er smoke
Old Mar 13, 2011 | 06:48 PM
TZFBird's Avatar
TZFBird is on a distinguished road
I'm not exactly sure what "the cover thing that goes over the throttle body" is exactly. But the best way I've found to introduce SeaFoam into an engine is through a vacuum line. The line that goes to the brake booster works the best. If not, you would need to remove the boot from the throttle body to access the blade.
I think your method of application was the issue. There should be no problem with getting it to smoke if done corecctly. As far as putting it in the oil to get it to smoke... I suppose if you like knowing you have leaking rings and valve-stems seals.
Old Mar 13, 2011 | 11:20 PM
LowLife's Avatar
LowLife is on a distinguished road
does not have to go in to the oil to make a smoke screen, i have done this 50 or so times all u do is pour it into the main vac off the brake booster and the smoke comes out like crazy, hope this helps
megapossum
Apr 13, 2015 06:10 AM
LannyL81
Oct 30, 2011 12:43 PM
kyle123
Apr 3, 2010 05:13 PM
ctberry78
Aug 18, 2009 08:18 AM
SniperX13
Jun 25, 2006 10:17 PM
