Idle Issues?
Old Jul 13, 2011 | 08:27 PM
chinlo777's Avatar
chinlo777 is on a distinguished road
Question Idle Issues?
1992 Full Size Blazer 5.7L 350 small Fuel Injected! It seems that my truck is having idle issues. In park shes at about 900Rpm but when I go into drive the engine goes as low as 200 and will stay there its not boggy very smooth but very low, on another note this might even be connected my voltage gauge jumps around from time to time. Alternator? Battery? Any help would be greatly appreciated. Christian Cauble
First time post.
Old Jul 13, 2011 | 08:37 PM
Does the voltage swings occur when the idle is low?
Old Jul 13, 2011 | 09:07 PM
chinlo777's Avatar
Yes, its seems so.
Old Jul 13, 2011 | 09:15 PM
Have you cleaned the IAC valve in the throttle body?
Old Jul 13, 2011 | 09:22 PM
chinlo777's Avatar
I havent, do you have a suggestion on what to use?
Old Jul 13, 2011 | 09:24 PM
chinlo777's Avatar
off the subject is that your 74 in that picture with the tahoe?
Old Jul 13, 2011 | 09:25 PM
chris015's Avatar
Just get some carb cleaner.
Its a round sensor on the left side of the throttle body. Use a pair of channel locks to unscrew it,spray the little piston down with the cleaner until its clean,also spray a little inside where it screws into,and use a old toothbrush (not wifes,she gets really pissed off) to help clean the inside.
Old Jul 13, 2011 | 09:33 PM
As chris wrote, just remove the IAC valve and clean both the valve and the bore it goes into with some carb cleaner. Get the sensor safe stuff which should be all that is available now. Some of the old stuff could damage O2 sensors if sprayed into a running engine.
They both are my vehicles.
blazer chris
Dec 8, 2011 09:56 AM
UnknownFish
22
Nov 14, 2011 07:40 AM
Chevrolet.Love
Aug 19, 2011 09:05 PM
97BLAZE4X4
Feb 7, 2010 07:33 PM
94pos
21
Jul 13, 2007 08:42 PM
