idler pulley
Old May 21, 2010 | 08:03 PM
fondo's Avatar
fondo has a little shameless behavior in the past
Default idler pulley
Has anyone ever replaced the idler pulley with an aftermarket one on a vin w motor. The stock idler has a steel cup that sits on the front of the idler and rides on the inner bearing. Not sure what purpose it served but it doesn't interchange with the aftermarket pulley so I didn't use it. Got the idler at carquest and it looks just like your standard pulley but its made out of steel unlike the stock one which seems to be made out of plastic. Just wondering if anyone has any input, thanks.
Old May 22, 2010 | 07:04 PM
AJBert's Avatar
I wouldn't worry too much as it is only an idler pulley. The most important part of it is the bearing.
And I did change one out on a 350 that was pretty much the way described the differences between stock and aftermarket and no problems at all.
Aesop
16
Apr 8, 2011 06:59 AM
drblaze
Dec 23, 2010 02:27 PM
dbaas
Nov 3, 2010 01:09 PM
truesmack
Oct 12, 2008 08:24 PM
jimbob533
Oct 3, 2007 03:13 PM
