idles fine Shuddering with gas
Old Nov 24, 2008 | 03:22 PM
marsh4005's Avatar
marsh4005 is an unknown quantity at this point
Default idles fine Shuddering with gas
So I had my 99' LT 4.3L home after a rotten seal in the water pump. After the water pump R2, The engine started just fine. drove about 400 yds then a shuddering when I gave it some gas. So I returned back to the driveway.
From there the car would not turn over there was shuddering backfiring and all. Finally it started and idled fine, but give it some gas in P or Dand it starts to shudder stalling at about 2000 RPM. It now will start, but has shuddering w/ any gas.
The only things I messed with while doing the water pump change was the take out the fan and fan clutch, Disconnect the battery, I also flushed the heater core with water to get crap out.
Any thoughts as to what might have happened.
Old Nov 24, 2008 | 05:11 PM
Default RE: idles fine Shuddering with gas
Did you make sure to get all of the lines back onto every where they came off. Did you remove the intake tubing? Check the back of the intake hat where the 3/4" tube from the passenger side valve cover meets it.
Old Nov 24, 2008 | 05:39 PM
marsh4005's Avatar
Yes the tubing seems fine. It runs fine for about 1 min then starts missing, I can smell the fuel and see the black crap from the tail pipe. I dont think moisture is an issue as I changed the water pump yesterday.
Old Nov 24, 2008 | 05:41 PM
Disconnect the MAF sensor and see if it the problem clears up.
Old Nov 24, 2008 | 05:56 PM
marsh4005's Avatar
I guess I should have saied that I tried that onealready. This thing is just kickin my butt.
Old Nov 24, 2008 | 05:57 PM
Yes, please do tell us everything that you have done so as not to waste our time... That would help.
Have you done anything to rule out a plugged catalytic converter?
robinann
Jun 9, 2015 06:58 PM
NCSurvival
Nov 6, 2014 05:36 AM
jceney87
Jan 24, 2011 07:57 PM
wrencher73
Dec 27, 2010 08:35 PM
EricTrembath
Jan 19, 2009 04:49 PM
