Idles norm no power in passing gear
Old Mar 2, 2008 | 08:19 PM
Fast89z28's Avatar
Fast89z28 is an unknown quantity at this point
Default Idles norm no power in passing gear
I just bought a 1998 2 door blazer 4.3 4x4. i just finished the transplant of a same year 4.3 while the engine was out i R&R the intake gaskets with the fel-pro. To make a long story short it runs mint at idle and nomal light footed driving but when you nail it it kicks down but lacks power big time. no codes no service engine light??? ANY IDEAS i am about out i think its a vac leak but i am not sure of all the equip that uses it to trace. or even fuel i have hear alot of the spider whats the fuel PSI range also?? any input would be great!
Old Mar 3, 2008 | 05:53 AM
thegr81's Avatar
Default RE: Idles norm no power in passing gear
I would check the psi at the check valve near the fire wall for fuel pressure, I believe the range is 60 psi to about 55!! Also something else you could do is run fuel system cleaner and higher octane gas through the system to see if that helps!!
Old Mar 20, 2009 | 07:24 PM
watsonmt's Avatar
watsonmt is an unknown quantity at this point
did you solve this problem im haveing the same problem
Old Mar 20, 2009 | 08:50 PM
Wow... Old thread.
Old Mar 21, 2009 | 07:19 AM
watsonmt's Avatar
lol wow i know but its the same problem does it really matter how old it is just thought that someone might have known how this could be resolved
Old Mar 21, 2009 | 08:12 AM
Problem is when the original author has not logged in in close to a year... Not likely that you will get a response out of such an old thread.
Old Mar 21, 2009 | 09:17 AM
watsonmt's Avatar
oh well it just discribed exactly the problem that im haveing someone might know...
aro_chase99
Oct 8, 2013 02:25 PM
wrencher73
Dec 27, 2010 08:35 PM
ohsofly
18
Feb 13, 2010 02:21 AM
Rickc46
Dec 31, 2009 10:22 AM
agent305
Aug 14, 2007 02:33 PM
