injector/running rich?? 95 s10 blazer
Old Mar 12, 2009 | 08:25 AM
  #31
If the ticking is caused by a collapsed lifter or a wiped cam lobe, it could cause a misfire and rough running.
Old Mar 12, 2009 | 02:41 PM
  #32
rowe's Avatar
rowe is an unknown quantity at this point
hope i dont have to go in there,,,LMAO!!!
could it be possible if the fuel filter is clogged up
may cause it to run rough? cause the fuel pump(brand new)
was whining or buzzing(laboring) the other day.
Old Mar 12, 2009 | 03:20 PM
  #33
Having a fuel pressure tester installed while you are experiencing the problem would tell you if it is or not. If there is sufficient pressure, then the problem is not with the pump.
Old Apr 12, 2010 | 11:57 PM
  #34
akiyamatr7's Avatar
akiyamatr7 is on a distinguished road
Default rich condition
I'm new to this forum, and I have a 95 S10 thats been intermittently flashining SES light, scanner says rich condition, in the last year I've replace the following spider injecter, plugs, O2's, dist cap and rotor. I just checked the plugs again, and the ones on the driver side are the ones getting fouled, on some previous post I read something about replacing the fuel lines on the inside of the pleneum, I'm not sure any advice?
Thanks
ksimpson
14
Oct 7, 2013 05:25 AM
S104.3L
Mar 29, 2013 11:39 AM
ozzygoat
Apr 26, 2012 11:36 PM
Vince's04blazer
Jan 11, 2010 05:45 PM
uncledenny
Jan 8, 2010 04:09 PM
