Injectors are bad HELP!
Old Jan 24, 2015 | 04:33 PM
Joe Rubio's Avatar
Joe Rubio is on a distinguished road
Default Injectors are bad HELP!
Do you guys have any tips on changing the injectors. Which injectors should I buy, I heard too buy 2002 injectors because they arte built better than the 1996 model
Old Jan 25, 2015 | 10:36 AM
Gregg64's Avatar
Gregg64 is on a distinguished road
Well sounds like you really should test the entire fuel system first. since you say you need injectors you probably did a leak down test but did you do a Max Pump Pressure test? i would check that first then decide if you need a new spider assembly. If you do you want to use an AC Delco or Delphi MPI upgrade unit only. Do not use another brand spider assembly. On the older style spider you can just replace the injectors because they are not injectors they are poppet valves. The actual injector is inside the modual head. The new MPI unit has an electronic injector at the end of each fuel line to the manifold.
Old Jan 25, 2015 | 11:15 AM
07nhbpsi's Avatar
07nhbpsi is on a distinguished road
Actually he can use a BWD injector Assy...they are actually of a reliable quality!!!! Just ask the guru, Captain Hook!!! we've had this discussion in passing!!!
Old Jan 26, 2015 | 06:12 AM
Joe Rubio's Avatar
I did not do a leak down test or a pressure test mainly Bc my best friend works on cars for a living for over 35 years now and my truck also has all of the systopms for new poppets
Old Jan 26, 2015 | 06:13 AM
Joe Rubio's Avatar
She is running lean bad and warms up and she is great but will stall out at idle out of no where
Old Jan 27, 2015 | 07:16 PM
Gregg64's Avatar
Well, these symptoms can be caused by a few different situations on the 4.3 engine. That is why it is important to check the entire fuel delivery system on them. Why replace a 2 or 3 hundred dollar injection spider when it may only be a fuel pressure regulator or a 150 dollar fuel pump.
Old Feb 5, 2015 | 07:43 AM
Joe Rubio's Avatar
I'm going to replace the pressure regulator this weekend I'll let you guys know how she runs
rickt84
Jun 24, 2013 04:55 PM
mlp2000
Jan 29, 2011 06:19 PM
muaymendez
Mar 30, 2009 09:03 PM
Sunshine Coaster
Oct 14, 2007 03:21 AM
booblinker
Engine & Internal
Oct 16, 2006 05:05 PM
