Intake Question, 95 W Block. Goop or no?
Old Feb 4, 2010 | 06:41 AM
nineteensixtycaddy's Avatar
nineteensixtycaddy is on a distinguished road
Default Intake Question, 95 W Block. Goop or no?
Ok.... Not sure if this has been addressed before, but I've got to know.
Should you use some sort of glue/gasket maker/sealant etc... when putting on an air intake?
I've got the two piece intake, and I've already properly torqued down the bottom half, using new gaskets, and some gasket sealant. I'm about to put on the top half, after checking the spider f.i. system for leaks, and cleaning it up. I've just installed a new 4.3 block, and the last thing left is to put on this intake, set the timing, and fire it up.
So... should I just use the new gasket between the top and bottom half of the intake... or should I put some "goop" on the gasket?
Thanks
Chris
Old Feb 4, 2010 | 07:01 AM
Matt Krogman's Avatar
Matt Krogman is on a distinguished road
Just from personal experience/preference, I always apply a very thin bead of Permatex to the gasket being applied no matter what the application is. One nice thing it also does is help keep the gasket from moving around on you. But again a VERY thin bead is all you need!
mommaoften
Mar 18, 2013 08:26 AM
sarge150
Feb 22, 2013 11:08 AM
ComputerNerdBD
Headers, Intake, & Exhaust
Jan 5, 2012 04:53 PM
mr.hotrod
Jul 7, 2010 07:37 PM
lil_blazin
May 10, 2009 05:20 PM
